Assembly Instruction
FAQ
Racing Car-LK505
The car does not move after assembly
1.Spring cannot be wound or the spring cannot be fixed after winding and rebounds directly.
Check if Parts P22 and C5 are missing.
2.The spring is wound and can store energy, but the car does not move.
Check if the direction of P18 is wrong.
3.The spring is wound and can store energy, but the car does not go far.
Check if the transparent rubber sleeve plays an anti-slip role.
If the transparent rubber sleeve is too loose, it is not acceptable.
If it is loose, replace it with a new one. Check if the steel shaft is fixed by part.
